It is currently Tue Aug 12, 2025 1:32 am
 Post subject: Cherry Neck Situation
PostPosted: Thu Feb 01, 2018 5:07 pm
Last Name: Sollod
In carving this cherry neck I ran into a sap pocket or something... I'm hoping I will carve past it. I've got a ways to go yet. I'm at 1.200" Shooting for about 0.830" This is my first cherry neck. I like the way it carves. Any ideas to deal with this spot if I don't carve through it?
www.swiftcreekguitars.com
PostPosted: Thu Feb 01, 2018 5:30 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That is part of cherry's charm. As it is now, I don't think it would look bad once it has finish on it and the color darkens a bit. But I like the look of cherry and am not as fearful of color/grain imperfections as some are.
Bryan Bear PMoMC
PostPosted: Thu Feb 01, 2018 6:58 pm
I'm with Bryan. Kinda comes with the territory.
Ken Franklin
clumsy yet persistent
PostPosted: Thu Feb 01, 2018 7:51 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Put a piece of cherry in direct sunlight for a day, and it will oxidize to a darker colour, with a bit of a grey hue. Under finish it will darken even more. This might be an easy way to even the colour of the neck without having to use stain.
The oxidation goes fairly deep, so sanding it out is very difficult, so only do it if you are sure!
Alex
PostPosted: Thu Feb 01, 2018 8:05 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
dark cherry water based gel stain sand w 320 , thenseal with redddish coloured shellac e.g. siam or kusmi??
PostPosted: Thu Feb 01, 2018 9:22 pm
Last Name: Howell
City: Atlanta
State: Ga
1+. the dye/stain will cover it. I have done similar.
PostPosted: Fri Feb 02, 2018 12:18 am
First name: Fred
City: Winnipeg
I am with it is part of Cherry's charm. Reminds us wood comes from a tree.
PostPosted: Sat Feb 03, 2018 6:28 pm
First name: David
Last Name: Riedmiller
State: WI
Alex
Years ago when I was a interior finish carpenter. If the woodwork was cherry with little or no stain we would cover the wood with drop cloths to keep UV’s off the wood.
It only takes a couple days exposure for the cherry to darken dramatically. If we did not cover it we would get lines not unlike sticker lines from a wood kiln. Pitch pockets etc. are part of the “charm” of cherry wood. I personally like it. Consider a dye or stain, as well.
"It is easier to fool a man, than it is to convince him that he has been fooled"
Mark Twain
These users thanked the author Rocky Road for the post: Pmaj7 (Sat Feb 03, 2018 7:58 pm)
PostPosted: Sat Feb 03, 2018 7:50 pm
I'm not a big fan of dye stains.
A good way to speed up the natural darkening of cherry is to wipe it down with a mild lye solution. It works best if you make your own from hardwood ash. You want to use a low concentration; it should just feel 'soapy'. If you want it darker you can use multiple coats.
Personally, on that neck I would not bother any sort of staining; use it as it is.
PostPosted: Sat Feb 03, 2018 10:04 pm
First name: Alex
Last Name: Kleon
City: Whitby
Alex
I learned the hard way. I was building a cherry Secretary desk many years ago, and left a bunch of dimensioned parts piled willy nilly on my table saw, right beside the window. I ended up having to make all new replacement pieces because of the shadowing.
Alex
PostPosted: Sat Feb 10, 2018 5:32 pm
Last Name: Sollod
I kept carving and I carved through the sap pocket... situation resolved... [:Y:]
I'm likin' the cherry. Carves nicely. It should look really nice with the cocobolo fingerboard on this one.
These users thanked the author sdsollod for the post: Bryan Bear (Sat Feb 10, 2018 6:52 pm)
PostPosted: Sat Feb 10, 2018 10:24 pm
First name: Gregor
Last Name: Crothers
Thanks for posting this Steve.
I have a lot of cherry boards that I plan to use for necks in the future; nice to have this tidbit.
Wake up and smell the rosewood!
